FlashPro release date and specifications
ronmcdon
Beverly Hills, CA
19 FiestaST, 19 Si, Camaro Z1LE, EvoX, 98 240sx
Curious what where the results of a cvt car, high tune (91 octane gas), injen cold air intake was.
Also would it be worth it to get the car further fine tuned with just a cold air intake? Im guessing getting a dyno tune would be at least a few hundred US dollars more.
Skeptical getting the car further tuned would be worth it with a couple of bolt ons, but could be wrong.
dc2turbo
usa
civic,teg
Civic CVT high octane (California 91 gas) plus 6 psi more boost, +25 HP and +35 lb-ft torque:
if you get it dyno tuned, you could raise the boost even more. Probably not worth getting a dyno tune if you just have a intake but if you do a downpipe then i would recommend it
ronmcdon
Beverly Hills, CA
Was that figure with or without CAI? I got the impression the 25hp increase didnt account for CAI but I could have misread the results or posts here.
Agreed a tune would likely be not necessary at this point if the only mod was an intake.
dc2turbo
usa
civic,teg
I just did a quick 0-60 on 19-20psi on 87 octane with injen intake only. It did it in 6.2seconds but its also 34F outside
TotalNoob
State College, PA
2016 Honda Civic Touring, 2015 BMW F 800 GSA
It'd be great if you could post a video of your 0-60 test once you get on 91-93 octane. Even better if you could post with and without the Injen intake! I'm on the fence about CAI's, but if it works it's a steal. Thanks for being the first one to report on your findings, we all appreciate it.
dc2turbo
usa
civic,teg
I will be on 93 soon. should be tonight or tomorrow since i got to drive 100miles. I will most likely wont do a stock intake run as i don't want to install it and take it off. I also just have a SRI.
I might take a video next time. I been using the phone to datalog while driving to make sure everything looks good. FlashPro has built in bluebooth where you can you use your smart phone as gauges. I have it prop up above the headunit.
You can get more sensors to show up in landscape mode
Honda Civic 10th gen FlashPro release date and specifications upload_2016-12-15_18-20-49
omigulay
Vancouver, Canada
2017 Civic Sport hatchback
If you have the other intakes, could you choose the injen option? Or is there a custom tune for that
16civicFLA
Orlando, FL
2016 Honda Civic EX-TL, 2016 Honda Pilot EX-L
If you have the mishimoto intake can you still just choose one of the injen options...?
VitViper
United States
Lots
The intake is an important component in the fueling calculations the ECU runs, it actually requires a tune to properly calibrate the MAF curve.
I am skeptical of any gains to be had, especially with it retaining the stock plastic piece. I'll get one to test and post results just for you guys.
VitViper
United States
Lots
You can try it, but from what I've seen, the mishimoto intake knocks off the maf calibration 7-20% to the rich end of the spectrum. It needs a proper MAF cal.
16civicFLA
Orlando, FL
As soon as it comes in I'll definitely upload different logs...
SilverGhost
Ktuner tuned X2 CivicX.
Bill
So close to hell i see sparks
2016 EXT,2017 Sport Hatchback09 Fit
Not as a default. You select the tune described "Civic Turbo CVT 2016 (or 2017) Tuned"
The next release of FlashPro Manager will have the tune description as "Civic Turbo CVT 2016 (or 2017) + 3 psi"
I went to upload my first tune from Vit but first I downloaded the new firmware and FP manager and now my FP unit is doing this.Refer to pictures.Just a few hours earlier I uploaded tune 3 off of the included baseline tunes worked perfectly.I also checked the serial number and it matches the locked FP I have except the number in FP manager it added a U.S here FP-16CIVIC-L1.5T "US"-2000033 the unit is marked FP-16CIVIC-L1.5T-2000033Could it be I need to update my drivers on my laptop?
