TypeCrane
- G Money
- Jun 2, 2017
- 2
- 24
- 28
- Boston Strong
- 2017 Civic Type R Touring
How long does it take to install a new engine harness?
There are actually 3 "engine harnesses" for the type R, but if you are referring to the harness that has the problem child connector that is throwing codes flat rate labor time calls for 3 hours on that one. this is the harness that would also contain your injectors, ignition coils, etc.How long does it take to install a new engine harness?
There are now two connectors unfortunatelyThere are actually 3 "engine harnesses" for the type R, but if you are referring to the harness that has the problem child connector that is throwing codes flat rate labor time calls for 3 hours on that one. this is the harness that would also contain your injectors, ignition coils, etc.
