DIY fog bulb replacement
Brony2012
Charlotte NC
2000 Honda Accord EX Sedan
So I'm changing my headlight and fog light bulbs for new ones, the headlight ones are easy, but I have no idea how to go about changing the fog lights. Should I just pay for someone to do it for me or just figure it out on my own? It's more so the safety tabs I'm worried about removing, and how to remove them I'm not sure. Any help would be appreciated.
FL
2017 Honda Civic EX-T, 2012 Honda Odyssey
i replaced my foglights w/ LED bulbs. it's pretty much unscrew w/ philips head screw driver or 10mm socket for the metal bolt then the 2 safety tabs towards the sides. the tabs doesn't take much to pry them w/ a flat head screw driver. i gently pulled out the protective plastic piece under the car and was able to access the light bulb. pretty much plug and play from there. less than 30 min install.
the only concern i had was that after the fog light installation, the housing unit had condensation/water in it now. make sure the new bulbs and their red gaskets are matching OEM sizes or else it'll fog up the housing unit.
