1. Guest, see the CivicX Forum Rules and User Agreement before posting.  After reading click here to dismiss this notice →
DIY: Clear side marker lamp housing swap
Discussion in 'DIY guides and requests' started by Dretlaw, Aug 4, 2016.
  1. Dretlaw
    Dretlaw Senior Member
    Rank:
    Mar 31, 2016
    1,650
    1,349
    2016 Civic Touring WOP
    Garage Profiles:
    Here's a DIY for the clear side marker lamp swap. Hope it helps:
    Tools you will need: Phillips screw driver, small screw driver, sharp knife/dremmel tool/X-acto knife.
    1. First turn the wheel to have better access to the wheel liner and side marker. On the edge of the wheel well, there are 3 screws. Remove them. The wheel well liner is flexible so pry it slightly to the side to expose the larger orange tab (it looks like it has ridges).
    2. With some force, push forward on those ridges (towards the front of the car) to untab it while pushing outward on the lamp housing. The lamp housing should pop out. The cable harness is very short, so be careful not to pull on it.
    3. You will see the harness connection of the bulb socket. You will find a slot and a small tab that's holding the socket in place. Use a small screw driver or even the tip of a knife to lift the tab and disconnect the socket from the harness. Be careful not to let the harness fall into the hole once separated.
    4. Unscrew the socket from the orange side markers. In close inspection, you will notice that there are 4 tabs that slot the original socket into the orange markers. You will need to trim the two small side tabs using the sharp knife/dremmel/X-acto knife as best as you can. You may want remove the rubber ring gasket to prevent it from being cut accidentally and then replace it after trimming. The two small side tabs needs to be removed, because the socket that came with the clear side markers are incompatible with the harness. The pin connectors are different and it is smaller in size. You cannot use the ones that came with the clear side markers. You must use the original that came with the car. The clear side marker housing socket hole only has two slots for the tab to fit into. Once the two small side tabs are removed from the original bulb socket, it will now be able to fit properly into the clear side lamps.
    5. If you have an LED bulb replacement, you may swap them now. If not, you may use the amber bulbs that came with the clear side markers. I ordered the Sylvania 194a (amber) bulbs from Amazon. They are frosted white in appearance but light up amber in color. They blend well with the white interior of the clear markers. The filament bulbs that came with the original socket are wedged in very tightly so be sure to grip it with a towel in case it shatters/breaks while being pulled out. Due to possible polarity connection with the LED bulbs, test its placement by reattaching the socket back to the harness and turning on the parking lights. If it doesn't light up, unplug the LED bulb, turn it 180 degrees, and place it back in the socket. Be sure to turn off the parking lights prior to working on the other side.
    6. Once the LED bulb test is successful, you may detach the socket again from the harness. I had to do this, because the harness was too short. I didn't have much room to reassemble the clear markers to the socket while it's attached to the harness. If you are able to do it without this step, great!
    7. Once all the harness, socket, and clear markers are assembled together, install the side markers back to the body, starting with the smaller tab in front into the small square hole and then the bigger tab into the larger square hole. Push on the outside of the housing with enough pressure until you hear the larger tab click. If it's loose and comes out, it hasn't tabbed in correctly and will need to be helped in. It might look flush, but a little bit of tug will pull it out. Some members were able to reattach the housing easily as it made a loud clicking noise, while others had a difficult time. If it's not clicking in place, you may stick a screw driver into the tab and help it in while pushing on the outside of the housing. The ridges need to clear the thin square metal hole to click in properly.
    8. Repeat on the other side.
    Here's the process in photos:
    Disclaimer: Some countries' traffic laws consider clear side markers illegal; therefore, it is strongly advised that anyone considering this modification consult their regions' respective traffic laws prior to making changes to his/her exterior lighting. This modification is solely at the owner's discretion and all liability is solely the responsibility of the vehicle's owner.
    irison, Fanoflive, Acey and 24 others thanked this.
  2. elvisfan48640
    elvisfan48640 Senior Member
    Rank:
    May 30, 2016
    90
    121
    Michigan
    2016 Honda Civic Touring Sedan
    Garage Profiles:
    It's also a good idea to remove the rubber gasket before trimming off the tabs in order to prevent damage to it. It rolls right off and back on again.
  3. frnkp
    frnkp Senior Member
    Rank:
    Apr 28, 2016
    199
    130
    Mobile AL
    2006 Civic Si and 2016 Civic LX Coupe (6spd)
    Garage Profiles:
    I'm not 100% sure but from what I can tell the sedan and coupe both use the same light.. Can anyone verify?
  4. Elvis 66
    Elvis 66 Senior Member
    Rank:
    Jun 21, 2016
    141
    112
    hi Desert California
    2016 civic 2015 mustang. 2001 tundra..1997 4runner..1972 chevelle 1966 Lemans
    Yes they do
  5. OP
    Dretlaw
    Rank:
    Mar 31, 2016
    1,650
    1,349
    Garage Profiles:
    I will add that to the post! Thanks.
  6. ams.soltis
    ams.soltis New Member
    Rank:
    Aug 3, 2016
    Occupation:
    Student
    Virgina
    2016 Honda Civic Touring Cosmic Blue
    Garage Profiles:
    Can you put a link to the clear side markers?
  7. OP
    Dretlaw
    Rank:
    Mar 31, 2016
    1,650
    1,349
    Garage Profiles:
    Unibrow Tail Lights and ams.soltis thanked this.
  8. ams.soltis
    Rank:
    Aug 3, 2016
    Occupation:
    Student
    Virgina
    Garage Profiles:
    Dretlaw thanked this.
  9. OP
    Dretlaw
    Rank:
    Mar 31, 2016
    1,650
    1,349
    Garage Profiles:
  10. kmai007 Member
    Rank:
    May 24, 2016
    omaha
    honda civic touring, lexus rx350
    Garage Profiles:
    Thank you so much for this. I just ordered my side markers today also.
  11. kmai007 Member
    Rank:
    May 24, 2016
    omaha
    Garage Profiles:
    Are there side marker bulbs that are LED?
  12. OP
    Dretlaw
    Rank:
    Mar 31, 2016
    1,650
    1,349
    Garage Profiles:
    Yes. I ordered the Sylvania 194a (amber). The are frosted tips but light up as ambers. They blend well with the interior of the clear side markers as you can tell from my last photo (no orange at all). I ordered mine via Amazon and get the one that comes in a 2-pack. Best of luck!
    ryansommer thanked this.
  13. kyr0sis
    kyr0sis Member
    Rank:
    Jul 9, 2016
    Ottawa
    THANK U SO MUCH FOR THIS!! I had them installed wrong, I initially thought you had to trim down the large clip because i couldnt get it to snap in place. I was using the bulb casing that came with the clear sidemarkers. Just went to dealer today to get my ASEAN black front grill assembly installed and they couldnt fit the sidemarkers on after they took off the bumper. Came on here and found ur post and fixed my problem, thanks so much it's greatly appreciated!
  14. OP
    Dretlaw
    Rank:
    Mar 31, 2016
    1,650
    1,349
    Garage Profiles:
    You're welcome! Can you please PM photos of your ASEAN grill? Thanks!
  15. kqn
    kqn Senior Member
    Rank:
    Mar 9, 2016
    141
    140
    Orange County, California
    2016 Honda Civic EX-T
    Garage Profiles:
    You've peer pressured enough @Dretlaw
    papashack, CivicLX2016 and Dretlaw thanked this.
Similar Threads Forum Date
DIY Muffler Delete Engine / Exhaust / Transmission / Tuning Jul 12, 2017
DIY: Beauty Washers DIY guides and requests Jul 5, 2017
Minder B DIY? Maintenance & Servicing: Break-in | Oil & Fluids | Technical Docs Jun 2, 2017
DIY : Installing Lane Watch on Type R DIY guides and requests May 31, 2017
REQUEST: DIY installing lowering springs DIY guides and requests May 29, 2017
DIY: Smoked side marker DIY guides and requests May 20, 2017
