I was reading the spec sheets on the Hondanews releases and it says that the 2.0L engine is port injected...Since both the 1.5T and 2.0L are DI, I assume they might eventually have carbon buildup?
Maybe Honda managed to program the ECU to reduce carbon deposits. Theoretically it can be done by adjusting spark and valve timing.No one has cracked that one yet. Even the new DI WRX is having gnarly buildup and requiring walnut blasting to a tune of $450+ a pop.
Only cars equipped with dual PFI/DI escape this issue. BRZ, FR-S, Toyota's newest DI V6, and the new NSX are a few to use 2 injectors per cylinder.
Gonna be interesting to see how this plays out for the Civic.
I think Mazda and Ford have both gotten good results on their current designs. Ford tweaked the ECU timing and exhaust pulse on their Ecotech for smoother flow (earlier iterations suffered pretty bad as the intake valve was exposed to unburnt fuel). Mazda designed the Skyactive to maintain temps at the intake valves above 400*. Time will tell... but for now both setups have been reported to have minimal accumulation.No one has cracked that one yet. Even the new DI WRX is having gnarly buildup and requiring walnut blasting to a tune of $450+ a pop.
Not necessarily true. Car manufacturers are going with DI turbos inspite of the carbon buildup problem for one reason- In order to meet Obama's draconian new CAFE/CO2 regs. They have no choice. All for a meager .5 MPG gain.Honda wouldn't have done direct injection of they hadn't solved the carbon buildup issue.
I'm just now getting very educated on this topic. A catch can only works if the oil vapors cool off long enough to condense; otherwise the oil vapors pass right through and back into the intake port.This engine will have carbon build up..I installed a mishimoto oil catch can. After 900 miles, the can is still empty but the baffle already has a level of wet engine oil. My HB just past 4000 miles this week.
Not sure the Founding Fathers had ICE and CAFE standards in mind when writing the constitution... but this isn't exactly a forum for political discourseAmazing how one man can destroy car engines without any real constitutional authority.
