CTR subwoofer swap
Trey
Trey
R-00621
Atlanta, GA
2017 CTR #00621
Doh! I had the polarity reversed on the sub. For the record, on the harness the white wire is positive and red is negative. Sounds a lot cleaner/ better but an aftermarket amp is the way to go.
@17CivicTypeR_Brian
17CivicTypeR_Brian
York PA USA
@17CivicTypeR_Brian
That's awesome!
Sorta off topic - where did you locate that plug pinout? I need others!!
Trey
Trey
R-00621
Atlanta, GA
2017 CTR #00621
RP2000R
WA
21 Porsche GT4, 20 Civic Si, 15 Lexus IS350 RWD
Trey,
Is the wire on the factory subwoofer inclosure red+ and red/black-?
Thanks for clarifying!
RP2000R
WA
I see in your pic where you grabbed power for your enclosure. When I hooked up my punch in the factory enclosure I assumed red+ and black with red stripe was negative.
If it's opposite my sub is hooked up backwards too...
RP2000R
WA
I have it correct. This pic solved my issue...LOL
leehom
under your bed
Honda, back at it again
Would replacing the stock sub in the factory enclosure be an improvement?
