17CivicTypeR_Brian
- Oct 14, 2015
- 113
- 3,608
- 2,759
- York PA USA
- '17 Black CTR #4071, 16 MDX Tech
Guys,
It's just slightly early on this but if you want to other-market your US CTR, you're going to need some part numbers. Hopefully this thread will lead to some parts exchange between US and UK at a minimum!
Bumper Side Marker Lights- US lenses are amber. EDM lenses are clear. JDM are ? Canada are Amber. Likely direct swap, no mod required.
US- 33800-TBA-A02-Passenger Side, 33850-TBA-A02-Driver Side
EDM- 34350-tet-h01 (unknown side, but probably 'Driver')
JDM-
Canada - probably the same
Tail lights - US housing has no REAR Foglights. EDM has rear fog lights. JDM probably has rear fog lights. Canada probably does not have Rear foglights. Should be an easy swap in except for getting the rear fog light to work...
US- 33500-TGG-A01 Passenger Side, 33550-TGG-A01-Driver Side
EDM-
JDM-
Canada? Same as US?
Headlight/Foglight stalk - US will have headlight and foglight. EDM/JDM probably has control for rear fog. Canada probably follows US. This switch mounts to the Left of the steering wheel. Modification to the connector is likely if doing a rear fog light swap/installation.
US - 35255-T2A-X42
EDM-
JDM
Canada?
Side Mirrors - US side mirrors are power adjust but not likely Defrosted or Power Folding. EDM has Power, Power Fold, and probably Defrost. JDM is probably the same as EDM. Canada probably has Defrost but not Power Fold. It appears the colored portion is just a snap-on piece meaning you buy the mirror assembly and you buy the color-matching portion separately.
US- *These mirrors have LaneWatch* - 76208-TGG-307-Pass Side 76258-TGG-307-Driver Side.
EDM-
JDM-
Canada-
side Mirror adjuster switch- US will not have power fold. EDM/JDM should. Canada unknown. In the past, the harness that plugs into this switch was the same, 8 or 10 pin connector, it just had blank pins in the US that were occupied in the EDM/JDM by the Defrost or Power Fold signal wires.
US-35190-T6A-J01
EDM-
JDM-
Canada?
More to come - CTR Seats w/ Seat Heaters, bumpers w/wo sensing, LDW parts, LKA parts, ACC parts, and parking sensors. Feel free to contribute guys! I'll try to edit this post with updated part #'s so they aren't all strung out through the thread.
JDM-
EDM-
JDM-
Canada? Same as US?
US - 35255-T2A-X42
EDM-
JDM
Canada?
EDM-
JDM-
Canada-
US-35190-T6A-J01
EDM-
JDM-
Canada?
