Not sure if anyone has tested them on the vehicle, but there are CTR compatible sizes:Any news on Advan GT? I saw a post on FB in the Enthusiasts group with a pic of them, I think the guy is from Evasive.
I wonder if the 19x9.5 +35 would poke out too much. 38mm more poke than OEM. +49 sounds pretty ideal, would only poke out about an inch more than stock and reduces the positive scrub.Not sure if anyone has tested them on the vehicle, but there are CTR compatible sizes:
18x8.5 +35
18x9 +53
18x9.5 +35
19x8.5 +35
19x9.5 +49
19x9.5 +35
These are all available in with the standard GT finishes but only the 18x9 +53 is available in the GT Premium Trim
It'll work with the right tire (aggressive compound 245 or less aggressive 255), but I would definitely recommend 9.5 +49 so you can comfortably run a 265 tireI wonder if the 19x9.5 +35 would poke out too much. 38mm more poke than OEM. +49 sounds pretty ideal, would only poke out about an inch more than stock and reduces the positive scrub.
I like your thinking. Can you get me pricing on these in white? (please PM)It'll work with the right tire (aggressive compound 245 or less aggressive 255), but I would definitely recommend 9.5 +49 so you can comfortably run a 265 tire
doneI like your thinking. Can you get me pricing on these in white? (please PM)
What are the specs again? So I can link it from the first page. Also looks great!Finally put on the Enkei's. Only have about 20 miles driven on them, but so far they feel very similar to the OEM setup. The caliper clearance is about the same as the OEM set as well. I'll try to get some better pics when it's not so dark.
Thanks! They are Enkei Raijin 19x8 +42. Wheels are Conti ExtremeContact Sport 245/35What are the specs again? So I can link it from the first page. Also looks great!
Thanks so much for the update - I really like those wheels. They look great on your CTR - 'Guess I have all the info I need - going to order these this week.Finally put on the Enkei's. Only have about 20 miles driven on them, but so far they feel very similar to the OEM setup. The caliper clearance is about the same as the OEM set as well. I'll try to get some better pics when it's not so dark.
They are. Unfortunately they didn't fit. The inside ring that snaps it in place was a little too small for these wheels. Thawk had started a different thread where he had the same issue with Center Caps he ordered on Ebay and some Sparko wheels. He was able to use a 3D printer to print a new plastic ring to put on the center caps to make them fit. He was nice enough to make me a set to try with the OEM center caps. They weren't easy to fit on because they were a bit different than the center caps he had but after a bit of effort it worked and they snapped in just fine! So a huge thanks to Thawk for helping me with that issue!Hey rey2300 - Are those oem Honda center caps on the Enkei Raijins?
setup looks good when you get a chance can you post side pics? I noticed there also available in 19x8.5 et38 do you think those specs would clear the calipers as well?Thanks! They are Enkei Raijin 19x8 +42. Wheels are Conti ExtremeContact Sport 245/35
