yep, dealer just replaced my screen, tech line finally authorized them to do this and its been a few weeks and all good so farI notice this usually when I am driving. The console keeps beeping at me as if I am missing an urgent notification.
I restarted the console and it didn't come back for a while. Do others have this problem too?
How did you show them? Did someone from Honda observe it happen in your car? For me it randomly occurs .. Or did they take your word for it?yep, dealer just replaced my screen, tech line finally authorized them to do this and its been a few weeks and all good so far
I had video of it on my phoneHow did you show them? Did someone from Honda observe it happen in your car? For me it randomly occurs .. Or did they take your word for it?
Not sure but first time I complained about it they didn't do anything but forwarded the video to tech line and a few weeks later tech line called my dealer back and told them to replace the screenSmart! I will do that next time. Is there any hardware differences from your upgrade?
Heard some chatter about a new console being available for the 2017 civic or that it has a different part #?
Had the same issue and reset it to default. Haven't had the issue in a few days, I'll record it with my phone next time as well. Did it take a while to replace the screen?Not sure but first time I complained about it they didn't do anything but forwarded the video to tech line and a few weeks later tech line called my dealer back and told them to replace the screen
I had this issue too. It is brand new. I would be on the Audio screen and it would switch back to the Home screen and beep. And then it would keep beeping randomly. No matter what screen I was on, it would always go back to the home screen. It was as if someone kept pressing the Home button. I had been playing with all the settings when it started happening. I realized that I had changed the Screen Sensitivity to High from Low. When I changed the sensitivity back to Low, the problem went away.Had the same issue and reset it to default. Haven't had the issue in a few days, I'll record it with my phone next time as well. Did it take a while to replace the screen?
Oh thanks I'll try that if it happens againI had this issue too. It is brand new. I would be on the Audio screen and it would switch back to the Home screen and beep. And then it would keep beeping randomly. No matter what screen I was on, it would always go back to the home screen. It was as if someone kept pressing the Home button. I had been playing with all the settings when it started happening. I realized that I had changed the Screen Sensitivity to High from Low. When I changed the sensitivity back to Low, the problem went away.
Is low sensitivity still working for you?I had this issue too. It is brand new. I would be on the Audio screen and it would switch back to the Home screen and beep. And then it would keep beeping randomly. No matter what screen I was on, it would always go back to the home screen. It was as if someone kept pressing the Home button. I had been playing with all the settings when it started happening. I realized that I had changed the Screen Sensitivity to High from Low. When I changed the sensitivity back to Low, the problem went away.
Yes, the issue has not returned.Is low sensitivity still working for you?
Thanks- Greg
Thanks. Set mine to low. Hopefully that will do the trick.Yes, the issue has not returned.
How do you do a software update? Do you have to take your vehicle to the dealer or can you do it OTA?I had this issue and a recent software update cured it.
Service bulletin 17-049
