Checking Transmission oil
Soamazen23
Orlando, FL
CivicX EX
Hello,
I just wanna know if anybody knows where the heck is the transmission dipstick on a 2.0 with a CVT. Maybe I havent looked hard enough. Im looking between the engine and battery area. If possible please post a picture.
Thank you very much!!!
frnkp
Mobile AL
2006 Civic Si and 2016 Civic LX Coupe (6spd)
I have a 6 speed but from what I can tell in the owners manual there's not a way to check the transmission fluid on a CVT, it just recommends changing it every 25,000 miles.
Honda Civic 10th gen Checking Transmission oil upload_2016-7-25_15-23-15
Soamazen23
Soamazen23
Orlando, FL
CivicX EX
That sucks. Ima have to measure exactly wat i take out. Thats the only way.
bhorn
Mobile, AL
'16 Civic EX HS Sedan
Hi fellow LA'er...
Where did you read about the fluid change interval for the CVT?
Billy4202
Will
Winchester, VA
Where'd you see every 25k? I've never found any documentation supporting this.
bhorn
Mobile, AL
I think I found the source of the 25K mile CVT fluid interval:
http://techinfo.honda.com/rjanisis/...M&t=H&model=CIVIC&year=2016&referer=ownerlink
Maintenance minder code 3 service:
Replace CVT fluid
NOTE: Using the wrong type of fluid will damage the transmission.
Honda Civic 10th gen Checking Transmission oil burret0003
Driving in mountainous areas at very low vehicle speeds or trailer towing results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the Maintenance Minder. If the vehicle is regularly driven under these conditions, have the transmission fluid changed every 25,000 miles (40,000 km).
Use Honda HCF-2.
Capacity
1.5 L engine models: 3.7 L (3.9 US qt)
2.0 L engine models: 3.5 L (3.7 US qt)
So the 25K mile is only for severe conditions. Otherwise just trust the computer to tell you when.
Billy4202
Will
Winchester, VA
Replace CVT fluid
Use Honda HCF-2.
Capacity
Right, I recall seeing this in the owner's manual. I'm guessing the car will say 40-50k for normal driving.
Civics4Ever
Rally Red EXT
Gene
Illinois
Brettjod
Okotoks, Alberta
2016 Honda Civic LX
I think a lot of new vehicles are not putting in dip sticks for the transmission fluid. My 2006 dodge magnum had a tube for the dealer to check it. I'd just leave it be and let the dealer deal with it when it's time.
JudgeCrater
GA
Civic, Ridgeline, Accord
My dealer said my Touring had no dipstick (which is true) and that if is not leaking, don't worry about it between changes.
Kalani
Savannah, GA.
2016 Honda Civic EX-L w/Navi MSM
The full owners manual actually claims that transmission fluid level should be checked monthly. I don't know about you guys/gals, but this seams like a huge inconvenience, as the level can only be checked at the dealership. "Ain't nobody got time for that!" This has been especially frustrating for me as I don't even trust my dealer anymore for services. I had them do my first oil change, and they over serviced it by 1 1/2 quarts! I like being self sufficient, and am trying to go the DIY route. Anyways, I've finally found a clue as to how to service the CVT on your own (didn't feel like playing the subscription fee for the service manual). Skip to around 12:25 for the fluid level check.
I know it's from a 2014 Accord Sport, but our transmission is very similar. Basically there is the fill port, which northern ex-t posted above (the plug at least), a drain bolt located on the underside of the transmission, and finally there is a, "check bolt," which is used to drain off excess transmission fluid after going through the procedures described in the video. I highly recommend watching the whole thing. Yeah, fight the power!:dance:
Honda Civic 10th gen Checking Transmission oil Screenshot_20160922-214202~01
Honda Civic 10th gen Checking Transmission oil Screenshot_20160922-222748~01
hunter44102
Cleveland
2006 Civic Hybrid, 2016 Civic Touring
Just buy a dipstick. On our Jeep Patriot you can use the oil dip stick to check the CVT fluid. (of course you have to make sure the stick is completely wiped clean of oil)
