trentcofax
If Honda tries to make me believe that my Lc2i and Kenwood KSC-SW11 underseat sub, with a combined current draw of <9amps from unused spots in the kick panel fuse block, and an iPhone plugged into the radio pull too much power which caused the fault, I am going to lose it. That sounds like one of the most ridiculous things I have heard recently. That would mean the issue could occur in every turbo civic with an aftermarket stereo system, extra illumination, etc. The new civic better not be that fragile.I have had the same issue with my prior EX-T coupe. It happened twice and I recorded it on my iPad to show the service department. The tech describe this if you use a lot of accessory power for example if you have the car on Accessory mode and are charging several objects like a phone or iPod or camera or even an iPad it can cause a drain on the battery and when you start your car up it throws up all these error codes and you know what? he was absolutely spot-on because that's exactly what I do in my car. So I stopped my using accessory power for an experiment using the accessory power and the symptoms went away. And Haven occured since. Hope this helps. My EX-T was stock tune.
