equeezy
- Sep 3, 2016
- 2
- 5
- 2
- Sacramento
- Honda Civic X
Has anyone thought of turboing their 2.0 Cylinder engine?
This is the conventional wisdom when someone asks about turboing their Altima, F150, Pinto, etc. This being a Honda K-series, it doesn't really apply to the K20C2 that lives in the LX/EX, which is, basically, a port injected, non-turbo variant of CTR engine. It does have a higher compression ratio than the CTR, by 1 point, but the CR is not so high that it cannot be turbo'd and run on pump gas at the same time. The 9th gen Si guys are running as much as 15 psi boost and getting 500+ whp out of their K24's and their CR is over 11:1. Hell, tc'd R18's are getting up to 400 whp on stock internals. This new K20 should deliver much more.No. Hardly any room in the engine compartment to begin with. Then, you can only boost so much given its high compression nature...then you have to replace the internals.
At that point, trade in your '16 Civic for an Evo, WRX STi, used BMW M3, used Mercedes C63 AMG or others would result in a better overall car.
If you absolutely have to have a Civic 2.0 Turbo no matter it makes sense or not, go for it. Expect your mileage and reliability to go down.
It won't cost anywhere near $70k when it's all said and done, not even half that. That is, if you do the work yourself.My point is that it doesn't financially make sense.
I can call Cosworth and they'll happily take my $25k and build me a Civic long block with all forged part - I'm sure it would withstand 12.5:1 with 20+ psi boost. 12.5 or even higher compression with even higher boost is done on many race cars, Gallardo, GT-R. Even de-stroking the crank and make that thing sing to 12,000+ RPM.
It's all possible and you are correct that been done before, but not many people are going to go "wow, it's a $70k Civic". Just go buy a used GT-R at that point.
There are other things that makes up a "sports car" - good chassis (which again, can be done - just take apart the car, spot weld the seams and put on braces), suspension geometry, brake system, etc. All can be done and improved.
Ask Prodrive - they serve anyone from Subaru World Rally Team, Mini World Rally Team, Aston Martin Racing and many more. At what price though? It makes sense for the manufacturers for promotion, but not for common people.
Say Civic is $20k base, $5k turbo kit, countless hours of time and visits to the shop, plus a few thousands for misc. stuff. Now, you have a great engine setup, but you have no way of slowing down. Here comes Brembo big brake kit, another $3k. Then I may grind the gears or CVT to pieces. Then it doesn't handle....the list goes on and on.
For some $33k, an Evo/STi/WRX has beefed up chassis, Brembo brakes, all wheel drive, ready to hit 400HP by a tune. High end part support, such as Hewland, Quaife, etc. are widely available, while civic "performance gearbox" would be tough to find.
If you have money and time, go for it. I'd just buy an Evo or STi. Been there, done that. If you can argue turbo'ing a Civic makes Civic a great value than an Evo, then I'm all ears.
Nonsense. You are correct that it wouldn't cost $70K, but wrong about the outcomes. First of all, there is no such thing as a "streetable" FWD car with 400 HP. About 300 HP is all you can practically use in a FWD car. Drag car is a different story, but that's not the subject of the conversation here. Second, you won't make 400HP with a "conservative" tune on this motor, not even at the crank, let alone the wheels. A reliable 300-325 at the wheels is doable with a good deal of boost. (and the increased fueling to support). I've been building 4-cylinder turbo cars for decades.It won't cost anywhere near $70k when it's all said and done, not even half that. That is, if you do the work yourself.
A drop-in turbo kit with a decent turbo, like a Borg-Warner EFR, will cost about $4k, with tuning and dyno time adding another $1k. This will give a reliable, streetable 400 whp (conservative) which the stock tranny will handle. So factor in a clutch/coilovers/brakes about $3-5k depending on quality.
That's great, but you seem to not be familiar with the K series. For instance, this KMOD performance stage 1 turbo will give 620 whp on a 9th gen Si, so this should give an idea as to what the new K20 is capable of. And there are plenty of other drop in kits that deliver similar #'s.Nonsense. You are correct that it wouldn't cost $70K, but wrong about the outcomes. First of all, there is no such thing as a "streetable" FWD car with 400 HP. About 300 HP is all you can practically use in a FWD car. Drag car is a different story, but that's not the subject of the conversation here. Second, you won't make 400HP with a "conservative" tune on this motor, not even at the crank, let alone the wheels. A reliable 300-325 at the wheels is doable with a good deal of boost. (and the increased fueling to support). I've been building 4-cylinder turbo cars for decades.
