1. Guest, see the CivicX Forum Rules and User Agreement before posting.  After reading click here to dismiss this notice →
Featured A guide to tuning the 10th Generation Civic 1.5 turbo
Discussion in 'Engine / Exhaust / Transmission / Tuning' started by Hondata, Dec 21, 2016.
  1. Hondata
    Hondata Hondata
    Rank:
    Nov 27, 2015
    68
    Featured Threads:
    245
    Occupation:
    Engineers
    Torrance California
    Home Page:
    06 Si, 12 Si
    Garage Profiles:
    We've put together a beginner's how-to video for tuning the 10th Generation Civic. Enjoy.
    Dcreek02, Civics4Ever, avidark22 and 17 others thanked this.
  2. dc2turbo Senior Member
    Rank:
    Jan 27, 2016
    723
    Featured Threads:
    340
    usa
    civic,teg
    Thanks for making the video. It explains a good bit of things on how the new ecu works
  3. Design Senior Member
    Rank:
    Sep 28, 2015
    1,230
    713
    Southern California
    09 MS3
    Probably the most important information is at 0:25, bullets #2 and #3. Don't overload the 1.5 with high midrange torque. This is how we snap the rods.
  4. 17siturb0 Senior Member
    Rank:
    Dec 3, 2016
    143
    79
    vermont
    2006 civic si coupe
    I feel like the internals are strong enough from the factory. It's the clutch and flywheel that will not hold up( depends on what you mean by over load in torque ), in which you'll need a new one and most upgraded clutch make the car show misfire codes. Obviously this is easily fixable with flashpro, but as far as passing the inspection with the plug in, I'm not sure if it will pass, off topic a bit but it's very important people know that.
  5. VitViper Member
    Rank:
    Apr 28, 2015
    38
    37
    United States
    Lots
    Torque is fun. My MS3 was making butt loads mid range and never snapped a rod. The Honda will be fine :p
    SilverGhost thanked this.
  6. Design Senior Member
    Rank:
    Sep 28, 2015
    1,230
    713
    Southern California
    09 MS3
    Funny you should mention...
    http://www.mazdaspeedforums.org/forum/f10/real-reason-people-breaking-rods-33010/
    For the 1.5 guys, a hard lesson learned in several other communities. And it's a good read into the science behind stress & tuning. One that Hondata is gently trying to advise that we avoid here.
    Syntek and Browncoat3000 thanked this.
  7. VitViper Member
    Rank:
    Apr 28, 2015
    38
    37
    United States
    Lots
  8. JS2000
    JS2000 Senior Member
    Rank:
    Nov 20, 2016
    131
    104
    Ontario, Canada
    Honda S2000 , Jeep
    Garage Profiles:
    The 1.5 l rods are plenty strong from what I've read of them.
  9. 17siturb0 Senior Member
    Rank:
    Dec 3, 2016
    143
    79
    vermont
    2006 civic si coupe
    They are plenty strong enough. I can only see needing a minor upgrade on the clutch. These 1.5t's are potent and well designed from the factory, internal wise.
  10. olivenoire Member
    Rank:
    Sep 30, 2016
    Featured Threads:
    luxembourg (europea)
    ep3 turboed
    SO if I understand well, no flashpro for the CTR FK2 ? Only for this 1.5. (Which is a good news)
  11. dc2turbo Senior Member
    Rank:
    Jan 27, 2016
    723
    Featured Threads:
    340
    usa
    civic,teg
    CTR isnt available in the STATES yet.
  12. olivenoire Member
    Rank:
    Sep 30, 2016
    Featured Threads:
    ep3 turboed
    Forgot about that, sorry.
  13. Design Senior Member
    Rank:
    Sep 28, 2015
    1,230
    713
    Southern California
    09 MS3
    Although common sense to mainstream enthusiasts, one more thing to add...
    The maintenance minder is no longer as accurate as it doesn't monitor a lot of the parameters that are modified through Flashpro. My recommendation is to do a UOA (used oil analysis) after each oil change to better understand the impact to oil quality. I'll let others chime in... but if it were me, I wouldn't let the oil integrity fall below 40% (initially). Keep an eye on the metal content and fuel dilution ratio. Anything above 1-2% might warrant changing the oil sooner.
    This is only my opinion... take it for what it's worth.
    Civics4Ever, Syntek and SilverGhost thanked this.
  14. partialprint
    partialprint Member
    Rank:
    Jan 4, 2017
    35
    Occupation:
    Graphic Designer / Musician
    BROWARD
    Home Page:
    2017 Civic Hatch Sport
    new to this is flashing erasing the stock memory on the cpu or what? is ther performance chips?
    my brother in law had a new a3 with vessels an exhaust and a performance chip and blew the engine
  15. 17siturb0 Senior Member
    Rank:
    Dec 3, 2016
    143
    79
    vermont
    2006 civic si coupe
    It doesn't erase.
Similar Threads Forum Date
Holiday Shopping Guide General 10th Gen Discussions Oct 30, 2016
Oil Change Guidelines Maintenance & Servicing: Break-in | Oil & Fluids | Technical Docs Oct 21, 2016
Is there a guide for how to hack the headunit? Audio / Nav / Electronics Sep 30, 2016
2017 Hatchback Owner's Manual & Guide General 10th Gen Discussions Sep 24, 2016
Buyer's Guide: Should I Buy an Si or Type R? Civic Type R Forum (10th Gen) Aug 25, 2016
Need a new door, requesting compatability guide Issues, Repairs, Warranty, TSB, Recalls Aug 9, 2016
