Kristina
- Oct 27, 2016
- 3
- 4
- 7
- Toronto, ON
- 2016 LX Manual
My 2016 LX 6MT has had, since new, a crack or pop noise that comes from the front end driver side on a) semi-aggressive deceleration at lower speeds, b) when getting off gas after aggressive acceleration, or c) the first reverse movement after forward travel (that is, if you reverse, stop, then reverse again, it doesn't do it - just on the first movement after moving forward).
It's directly linked to that force of the deceleration/reverse. It happens independent of braking, on two different sets of tires/rims, in gear or not. The noise is comparable to how a balljoint with no grease would 'crack' when forced to move.
I finally got the dealership to check it on my first oil change and they replicated the noise and had the mechanic and QC guy on it but say since the car is so new they have limited info on what it could be, and they can't tell precisely where it's coming from. They said they think maybe a driveshaft or suspension issue but will have to look into experiences at other dealerships to see if anyone else has had the same problem.
I'm not overly concerned but I would like to figure out what it is... anyone else have the same issue?
