beejpowers
- Sep 25, 2017
- 2
- 14
- 5
- Burke, VA
- 2017 Civic SI, 2013 VW GTI
First off, I cannot tell which trim level this headunit matches. It is a 10 speaker setup in the car.
Second, I'm assuming that the line feeding the stock sub has an LPF on it. Or does the HU or amp do actual crossovers?
Third, when people are replacing the sub, where are they getting their signal from? If the sub wires have an LPF on them, the new amp probably won't be getting all the signal range it needs to set better crossover points.
If you're tapping into the lines feeding the woofers, then the settings in the HU "EQ" (Treble, Mid, Bass) would directly affect the signal going to the amp. So if you turned bass down for the door woofers, it would be pulled out of the signal going to the new sub amp.
This is my first install using a factory head unit, so sorry for the questions and assumptions. I guess if I didn't care about using the A/C or heat, I could just pull it out!
