2017 Honda Civic EX Sedan - Canadian Wheel Size / Winter Tires
bconcha18
Cocnah
Saint John, NB
Honda Civic
Hi,
I'm going to be downgrading my 2017 Honda Civic EX tires from 215/55r/16 (Summer) to a different size in Winter. I've decided on the Blizzak WS80 as the winters here are quite rough.
I bought 15" steel rims already and I tried contacting the dealership and they are saying I should put on 205/65/r15.
The thing is, I think 195/65/R15 will fit as well but the tires will be $100 cheaper.. is the 10CM between 195 to 205 (with winter tires) worth the $100 difference?
Thanks guys... hopefully I have the right size!
Erin Tyres
Jeff
Vermont
2018 Civic EX-T
It is said that narrow tires tend to dig into the snow and work better. I believe it, but if the tires are much too narrow, they would give poor cornering performance.
The diameter of the 195/65R15 tires would be all right. They would have 1.2% less circumference, with a corresponding 1.2% speedometer error. You can see all the trade offs here: https://tiresize.com/calculator/
My 2018 EX-T came with 215/50R17 tires, and I plan to buy 205/65R15's. I was happy to see that the winter tires will have -exactly- the same rolling diameter that I have now. Also, the snow tires that I am considering have a slightly better load rating than the original tires. I am going to buy 15" Honda wheels, since it seems like OEM wheels are stronger, they work with the existing lug nuts, and they don't require any kind of spacers.
A mechanic told me that it helps to install wheel covers or to put some grease on the wheel hubs. Otherwise, the center of the wheel could rust.
Ocelot
Ben
Manitoba
'16 EX-T sedan, '12 LX sedan
I used 195/65r15's on my '12 lx every winter with x-ice tires in place of stock 205/55r16's. You'll be fine if the rim clears.
Cornering won't be a concern in cold weather wrt narrower tires, the cold weather will eat up more of your dry road traction than the slightly narrower tires ever will
razz
toronto
sentra
Have a 2017 civic ex with 215/55r/16 (summer). So what's best to install for winter?
215/55/16
205/60/16
195/65/15
Ocelot
Ben
Manitoba
narrowest is always best for snow and ice
