I guess that's just what the 2.4 Si does. Both of my 9th Si's had approximately the same unmodified mpg, low 20s. It's all city driving, plus our highway here is about a 10mph stop and go fest so it would be even worse there.How are you guys getting such low mpg figures? I get between 25-28 mpg on average in my >250k-mile S2000 while redlining multiple times daily.
Lol I average 14-16 MPG in my 50k mile AP1. But... I don't daily her and the only time she gets driven is to raise hell on the mtns etc.How are you guys getting such low mpg figures? I get between 25-28 mpg on average in my >250k-mile S2000 while redlining multiple times daily.
I don't care much about MPG either. Doesn't affect my decision in the slightest on a car.I may be the minority but MPG figures don't persuade my decision on what toy to buy.
Same here. The only car where it really became relevant at all was the Evo X, and then it wasn't the cost of the fuel that was a problem, it was the high consumption combined with a fuel tank the size of a thimble which meant the effective range before looking for fuel wasn't much over 100 miles, which was a real pain. My motorbike has three times that range!I don't care much about MPG either. Doesn't affect my decision in the slightest on a car.
I pull about 16mpg around town and maybe 21 if I get some mixed driving in my 09 Si. That's on E85 though, so maybe not a completely fair comparison!How are you guys getting such low mpg figures? I get between 25-28 mpg on average in my >250k-mile S2000 while redlining multiple times daily.
The 2.0T has been around a bit longer than the 1.5T but not by much. They were both developed at the same time under the Earth Dreams engines. The 2.0T was first used in the 9th gen CTR, the 1.5T was used in some Japanese vehicles before it came here for the Civic and CRV, but they're both current gen engines.Is the 2.0L turbo an older gen engine vs the 1.5T? That might explain it.
We aren't, someone had some insanely high MPG numbers on their Si so we all chimed in to that specific post, not the Type R.-Why in the world are people comparing the old 2.4L Si to the Type R... your Si doesn't have 300+ horsepower or 250+ torque... mpg numbers are NOT going to be comparable between these two cars. At least compare apples to apples and compare it to other 2.0T engines making 300hp or more.
Why not.-Why in the world are people comparing the old 2.4L Si to the Type R... your Si doesn't have 300+ horsepower or 250+ torque... mpg numbers are NOT going to be comparable between these two cars. At least compare apples to apples and compare it to other 2.0T engines making 300hp or more.
At the highway speed portion of the test, boost isn't a thing, and mpg is really a function of cfm/mi consumed through the engine, and cfm/mi is a function of rpm, and rpm is a function of mph-through-gearset, so turbo or not...it is fair to compare. We should expect lower city mpg because it will likely boost more, and higher highway. If anything, I would almost expect to see higher mpg numbers just based on the fact that the engine is Direct Injected and the epa drive cycle is rather light on the throttle.-Why in the world are people comparing the old 2.4L Si to the Type R... your Si doesn't have 300+ horsepower or 250+ torque... mpg numbers are NOT going to be comparable between these two cars. At least compare apples to apples and compare it to other 2.0T engines making 300hp or more.
Pretty sure it has to be in the default setting which, as I recall, is Sport.Any idea which setting this was from? I'm assuming comfort, but it'll be nice to have confirmation.
In that case, would it be okay to assume that comfort would be a little higher? Or are the setting based solely on suspension and ride quality.Pretty sure it has to be in the default setting which, as I recall, is Sport.
I believe throttle response as wellIn that case, would it be okay to assume that comfort would be a little higher? Or are the setting based solely on suspension and ride quality.
It should be safe to assume slightly higher but not a lot. Sport mode will offer a more responsive throttle which could certainly lead to a higher likelihood of consuming more fuel. I always set the MDX to Comfort on the highway so that the Cruise Control will be less likely to cause downshift on part/full throttle while accelerating back to cruising speed. You can set it to comfort and floor it, or set it to sport and floor it, and it consumes the same amount of fuel. The gains will be in the part throttle.In that case, would it be okay to assume that comfort would be a little higher? Or are the setting based solely on suspension and ride quality.
